BlackEyedAngel
Jun 18, 2009Aspirant
Most efficient way to move files between shares
I have a large quantity of media on my ReadyNAS NV+ which I want to move from share A to share B. Using my PC to do this is very tedious (it's estimating nearly 20hrs to move about 200gb) - am I ri...
TeknoJnky
Dec 01, 2010Hero
ivanek wrote:
TeknoJnky wrote: you do not need togglessh, its only needed for techsupport use.
Do you mean there is a possibility to copy files on ReadyNAS directly from one folder to another (without pushing files over network) without installing SSH?
Ivan
well yes, if you use scp or mount the /c share via admin user
but I don't think thats not what you mean... to get SSH access, you need ENABLE SSH addon, NOT the toggle SSH addon.
once you have SSH enabled, you simply SSH in (its like telnet but secure), then you use standard linux commands, like mv /sharename/foldername /sharename2/foldername2
