BlackEyedAngel
Jun 18, 2009Aspirant
Most efficient way to move files between shares
I have a large quantity of media on my ReadyNAS NV+ which I want to move from share A to share B. Using my PC to do this is very tedious (it's estimating nearly 20hrs to move about 200gb) - am I ri...
ivanek
Dec 02, 2010Aspirant
TeknoJnky wrote:
ivanek wrote: What I would like to do is to connect with my laptop to ReadyNAS NV+, enter commands to copy some files or folders from one place on ReadyNAS to another, then disconnect my laptop and let the process run entirely on ReadyNAS. Is that possible using SSH and ReadyNAS or some other way?
no, when you SSH in to your nas, its just like opening a command prompt, everything runs within the command prompt. The commands you enter are executed as soon as you press enter.
the process does take place on the nas, but you still must be connected.
I am not sure why this is all being so difficult, you can connect to the admistrative C share using the admin login as indicated in the thread already, and from there you can move files and folders from anywhere within the C share.
Yes, it works fine with moving files, but I need copy files, not move them.
Ivan
