twink
Nov 05, 2014Aspirant
Most preferred way to stream to TV?
I have a ReadyNAS 104. I'd like to stream avi and mp4 files from it to my TV. They are both connected to the network. What's the most preferred way of doing that? I'm guessing one way of doing it i...
ukbobboy
Jan 01, 2015Luminary
Hi again StephenB
As you can imagine, I do realise that converted files should have a similar size to that of the original and because of that I have looked into the settings and found the one most suitable to my requirements, i.e. quality of picture and my TV's (32 inch) screen size
The converter I am using is called: Free FLV to MP4 Converter
and is available from here: http://www.free-videoconverter.net
If you get a chance to look into this converter then let me know how you get on because I have found it very easy to use and the converted files do not suffer from any kind of degradation.
regards
UK Bob
regards
UK Bob
