n_damian
Dec 06, 2015Aspirant
Mount/access encrypted volume
Hello How to mount/access encrypted volume after reset the ReadyNAS to factory default? Before reset the ReadyNAS to factory default the encrypted disk was removed. After reset encrypted disk in gui...
- Dec 06, 2015
Power down, remove all disks (label order). Put just the encrypted disk in the NAS (same slot as before), connect the USB key and power on.
mdgm-ntgr
Dec 06, 2015NETGEAR Employee Retired
- n_damianDec 07, 2015Aspirant
Whether the disk encrypted on Readynas 104 (6.4.1) is compatible with Readynas 104 (6.4.1) or Readynas Ultra 2 (6.4.1).
Can I put disk encrypted on Readynas 104 into Readynas 102 (or Readynas Ultra 2).
