InterClaw
Sep 13, 2012Aspirant
Move from 6x2TB to 6x3TB
I'm not sure my current setup is okay to xraid my way onto 3TB drives (WD RED WD30EFRX). I don't remember, but I fear my current file system cannot handle larger drives than I have. What informatio...
mdgm-ntgr
Sep 13, 2012NETGEAR Employee Retired
If you are running RAIDiator 4.2.16 or later you can upgrade to 3TB drives. Best to be running the latest firmware though.
What disks were installed when you last did a factory default (e.g. 6x2TB)?
Are you using X-RAID2 single-redundancy or dual-redundancy?
