JanHussaarts2's avatar
May 21, 2020
Upgrade from Ultra6 (6x2TB) running OS 6 to RN426 (6x4TB)
Hi all,
A couple of days ago I bought a RN426. Yesterday I ordered 6x4TB HD's.
I have an Ultra6 with 6x2TB running OS 6.
I want to move all my applications and data from the Ultra 6 to the new RN426 and after that start using the Ultra 6 as a backup for the RN436.
What is the simplest way to achieve this?
Best regards,
Jan Hussaarts
  • I do not have the space to do a backup. That is why I will keep the Ultra 6. It will serve as a store for the backup of the RN426. Taking that into account, I should probably do a clean install.
  • By "applications", do you mean apps that run  on the NAS, or applications stored on it that are executed by a PC?
    Moving NAS app data is a bit complicated and depends on the app, so please list them if that's what you are referring to.  You can't move the apps themselves, you have to re-install them on the new NAS.  Whether you can move the data depends on how it's stored.
    Other than the apps, the best thing is to save the configuration on the old NAS and restore it on the new one.  If you've configured a static IP, you'll needd to take the old one offline or change it's address before you restore on the new one, or they will conflict with each other.
    If you do have apps, you should re-install them before restoring the saved configuration.  But that does not move any data associated with the apps will be restored, just some configuration items.
    To move the bulk of the data, set up backup jobs for each share.  RSYNC is the best protocol to insure all file permissions are also moved over.  Home folders need to be addresed differently if you use them.
    There is a really slow way to accomplish what you want if you don't need the old NAS to retain the data.  With power off, move all the drives from the old one to the new.  After it boots, replace the drives one at a time (with power on is best), allowing each to sync and expand as necessary.  When you are done with all six drives, the old ones will not be in sync, so you can't just put them back in the old NAS and have them work.  But you can put them in there and start over with it.  I personally don't like this option, as it moves any potential issues from one NAS to the other, too.
    • JanHussaarts2's avatar
      JanHussaarts2
      Luminary
      Yes, I mean apps runnig. E.g. Owncloud, MySQL, NZBGet, PHP 7.0, Gittea, ...
      The last option looks attractive.
      What I do not like about is, is the time it would take,
      Is there a guarantee that I will not destroy the original disks when I put them in the RN426?
      Or should I try to build the new drives on the utlra 6?
      I could also install the apps on the new machine. The only thing I consider cumbersome is Owncloud.
      It has some of its data in the SQL database. Ans I would like it to stay up and running for as long as possible.
      Isn't there some kind of migrate from old to new function that preserves the old disks and copies everything to the new NAS / disks? Including the software. E.g. something like an image copy of a diskdrive?
      • StephenB's avatar
        I don't know about guarantees.  But migration has worked quite well with OS-6.  I do suggest either matching the OS version on the two NAS before you begin, or alternatively upgrading the Ultra to 10.6.3 before you migrate.
        Expanding the volume on the Ultra will probably take longer than expanding it on the RN426.
        It is wise to have a backup before you migrate (or manipulate disks).
        While I take Sandshark's point on the benefits of starting out clean on the new system, if you have a lot of apps it's probably simpler to migrate the disks.
ProSupport for Business
