InterClaw
Sep 13, 2012Aspirant
Move from 6x2TB to 6x3TB
I'm not sure my current setup is okay to xraid my way onto 3TB drives (WD RED WD30EFRX). I don't remember, but I fear my current file system cannot handle larger drives than I have. What informatio...
Sep 13, 2012Guru - Experienced User
Personally I'd rather have fewer high capacity disks. The more disks you have installed, the higher your downstream disk replacement costs. Vibration also becomes an issue.
InterClaw wrote: Unless there are plans for any future "more than 6 disks" units?
Though one approach would be to sell an expansion bay module. That would give folks more options when they run out of slots.
Predict the future no one can. Sounding like Yoh-dah you are. :D
mdgm wrote: Clouded the future is.
