InterClaw
Sep 13, 2012Aspirant
Move from 6x2TB to 6x3TB
I'm not sure my current setup is okay to xraid my way onto 3TB drives (WD RED WD30EFRX). I don't remember, but I fear my current file system cannot handle larger drives than I have. What informatio...
Sep 13, 2012Guru - Experienced User
If you have a fast enough internet connection, you can also use cloud backup (for instance CrashPlan). Though that makes more sense for disaster recovery, since it would take a while to restore all your data.
InterClaw wrote: Thanks for your suggestion PapaBear although the Pro with 10TB won't be able to backup a new 15TB array. The problem right now is I'm running out of space. Not much of the data is really critical though so if I wanted to back that up I could just get a USB-drive or two...
Using the Pioneer as part of your overall backup strategy makes sense to me. You could hook up a couple of USB drives to the old NAS, and set up the Pioneer to back up all your data on schedule (some to the USB, some to the RAID array).
