plusterkopp
Mar 30, 2018Tutor
Move /home to another volume
I used to have two JBOD disks, one 3TB and one 4TB. The first one had /home mounted. I removed the 3TB to make room for a new 8TB disk. Copied files from the 4TB disk to the new one. Then put the 3TB...
plusterkopp
Mar 31, 2018Tutor
thanks a lot, the systemd config change did it. Alhough the question remains why this isn't reflected in the web gui. But then I am still using 6.8.1.
mdgm-ntgrwrote:There are systemd mount files for homes and apps. The path to mount is specified inside these files. You may need to manually update these.
Also check /etc/fstab to make sure the old volume isn’t still mentioned in that.
plusterkopp
Apr 14, 2018Tutor
while the system works now unsing SMB and other services, I can no longer use the admin page. Browser tells me it's offline, after logging in and overriding the browser's certificate panic.
Readynasd seems to have issues starting up properly:
systemctl status readynasd
● readynasd.service - ReadyNAS System Daemon
Loaded: loaded (/lib/systemd/system/readynasd.service; enabled; vendor preset: enabled)
Active: failed (Result: start-limit-hit) since Sun 2018-04-15 00:35:55 CEST; 14min ago
Process: 6828 ExecStart=/usr/sbin/readynasd -v 3 -t (code=exited, status=255)
Main PID: 6828 (code=exited, status=255)
Status: "Importing DB"
Apr 15 00:35:55 BingNAS systemd[1]: readynasd.service: Unit entered failed state.
Apr 15 00:35:55 BingNAS systemd[1]: readynasd.service: Failed with result 'exit-code'.
Apr 15 00:35:55 BingNAS systemd[1]: readynasd.service: Service hold-off time over, scheduling restart.
Apr 15 00:35:55 BingNAS systemd[1]: Stopped ReadyNAS System Daemon.
Apr 15 00:35:55 BingNAS systemd[1]: readynasd.service: Start request repeated too quickly.
Apr 15 00:35:55 BingNAS systemd[1]: Failed to start ReadyNAS System Daemon.
Apr 15 00:35:55 BingNAS systemd[1]: readynasd.service: Failed with result 'start-limit-hit'.
Is there any other config file that must be modified?
