ibell63
Jun 26, 2017Aspirant
Lost another volume
On firmware 6.7.4 ran a scrub before leaving for the weekend on Friday, came back in today after not having received a notification that the scrub had ever finished, couldn't make any changes to the contents of any shares, was getting permission denied, even on accounts that have read/write. Reset permissions for these shares.
Finally rebooted and now the volume has disappeared. To my knowledge this system has never suffered a power failure since the last time I rebuilt. Please let me know which logs to post if any.
Hi again,
Yes, so there is definitely some corruption on the filesystem - unfortunately. You can probably see that yourself reading through some of those messages. It would cause issues mounting the volume and thus you see no wolume anymore. This is not a result of the scrub by the way.
It is one of the problems with running a RAID0. You are much more prone to these sort of problems as there is no fault tolerance at all. If any of the disks were stalling or if there are errors on any of the disks it can cause serious issues for a RAID0. Are all the disks OK? You can check it in the disk_info.log
Do you have have a backup of the data? If so, you are best to factory default and restore from backups. Also, you might want to consider whether RAID0 is the correct RAID for your setup? It is rather risky on 4 drives I think.
- HopchenProdigy
Hi,
First thing is to check whether the data RAID is running. Can you please post the mdstat.log ?
Thanks
- ibell63Aspirant
mdstat.log
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md127 : active raid0 sda3[0] sdd3[3] sdc3[2] sdb3[1] 23422691328 blocks super 1.2 64k chunks md1 : active raid10 sda2[0] sdd2[3] sdc2[2] sdb2[1] 1046528 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU] md0 : active raid1 sda1[0] sdd1[3] sdc1[2] sdb1[1] 4190208 blocks super 1.2 [4/4] [UUUU] unused devices: <none> /dev/md/0: Version : 1.2 Creation Time : Mon Oct 10 14:44:16 2016 Raid Level : raid1 Array Size : 4190208 (4.00 GiB 4.29 GB) Used Dev Size : 4190208 (4.00 GiB 4.29 GB) Raid Devices : 4 Total Devices : 4 Persistence : Superblock is persistent Update Time : Mon Jun 26 12:53:42 2017 State : clean Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Name : 117c606a:0 (local to host 117c606a) UUID : 1d244df2:605bbba2:95ce8d48:297bec93 Events : 86 Number Major Minor RaidDevice State 0 8 1 0 active sync /dev/sda1 1 8 17 1 active sync /dev/sdb1 2 8 33 2 active sync /dev/sdc1 3 8 49 3 active sync /dev/sdd1 /dev/md/1: Version : 1.2 Creation Time : Mon May 15 18:47:04 2017 Raid Level : raid10 Array Size : 1046528 (1022.00 MiB 1071.64 MB) Used Dev Size : 523264 (511.00 MiB 535.82 MB) Raid Devices : 4 Total Devices : 4 Persistence : Superblock is persistent Update Time : Mon Jun 26 10:41:10 2017 State : clean Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Layout : near=2 Chunk Size : 512K Name : 117c606a:1 (local to host 117c606a) UUID : 7eb71118:4e648fc4:7b53a41b:99cd94fa Events : 19 Number Major Minor RaidDevice State 0 8 2 0 active sync set-A /dev/sda2 1 8 18 1 active sync set-B /dev/sdb2 2 8 34 2 active sync set-A /dev/sdc2 3 8 50 3 active sync set-B /dev/sdd2 /dev/md/data-0: Version : 1.2 Creation Time : Mon May 15 18:47:04 2017 Raid Level : raid0 Array Size : 23422691328 (22337.62 GiB 23984.84 GB) Raid Devices : 4 Total Devices : 4 Persistence : Superblock is persistent Update Time : Mon May 15 18:47:04 2017 State : clean Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Chunk Size : 64K Name : 117c606a:data-0 (local to host 117c606a) UUID : 7abc2a8b:b6a7cb06:e80da4b0:8c8d78e6 Events : 0 Number Major Minor RaidDevice State 0 8 3 0 active sync /dev/sda3 1 8 19 1 active sync /dev/sdb3 2 8 35 2 active sync /dev/sdc3 3 8 51 3 active sync /dev/sdd3- HopchenProdigy
Okay, so your data RAID is active which is good. But I can see that it is a RAID0. A scrub will have no effect on a RAID0 as there is no redundancy to recover from in case of the filesystem finding corrupt versions of your files during the scrub. So, if you run a RAID0 (or any other RAID with no redundancy), don't run a scrub.
That being said, the scrub shouldn't break the volume - it just won't do anything useful. Can you enable SSH access and login to the CLI of the NAS and run this command:
journalctl | grep -i btrfs
It is to see if the system logged any filesystem warnings. We need to see if the filesystem is OK.
Thanks
