ghdweb
Nov 25, 2008Aspirant
Moving files between shares
I'm moving files around on my ready nas, having setup backup jobs to copy all my data from an external USB drive to my shares. Problem is, it's shockingly slow, taking hours to move folders of a few...
zanduo
Sep 23, 2012Aspirant
I tried this:
Extplorer addon but it fails every time I try to move or copy a file; checking share permissions, the share should be wide open.....
FileZilla client from my pc and while I can make a SFTP connection and get root access, again, any file move fails. I have to blame this on some sort of access from the FTP to the share but I've checked and double checked and can't figure it out. Same thing with WinSCP client from my pc
Same failure issue with the ExploreBoard addon
Here is what is working for me now:
I make a PuTTY connection to my NAS with root SSH access. I then use the mv command to move a file or directory where I want, ie: Movies.
PuTTY stops responding at that point (it will come back if you leave it open once the move is complete) so you don't really know if it is doing anything, but if I get up and go over to the NAS and external USB both have lights blinking indicating data is being moved.
Then I launch Beyond Compare on my pc and enter the original location on the left and the new NAS location on the right, showing me the files at both locations. I use F5 to refresh the view showing the data growing on the right. A final compare afterwards of another location that contains a full copy of the files I'm moving ensures me all the data has moved entirely as no differences are shown.
