Readyboi
Sep 01, 2015Aspirant
Moving from RAID 0 to X-RAID or RAID 1? [Ultra 2]
I have an Ultra 2 with a single drive set as RAID 0. When adding a second (identical) drive I am not getting the option to use X-RAID or RAID1 for redundancy. I previously had this drive set up ...
Sep 01, 2015Guru - Experienced User
If you are ok with setting up the NAS again from scratch you can simply do a factory reset.
That will destroy all data, and you'd need to reconfigure the NAS and reinstall your addons.
Readyboi
Sep 02, 2015Aspirant
StephenB wrote:If you are ok with setting up the NAS again from scratch you can simply do a factory reset.
Trying to avoid that if at all possible!
- StephenBSep 02, 2015Guru - Experienced User
If you don't have a backup, now would be an excellent time to make one.
