jackaninny
Nov 06, 2011Aspirant
Moving from ReadyNAS NV to Pro 6 - Best plan?
I'm getting ready to move over to a new Pro 6 from our existing NV unit. Current NV unit is running 4.00c1-p2 firmware and has about 800GB of data stored on it.
What is the best method of moving data from the NV unit to the Pro 6?
- tenneyAspirantyep
- mdgm-ntgrNETGEAR Employee RetiredSo that worked fine?
You might want to contact NetGear tech support (http://www.readynas.com/support) and see if they have some suggestions.
If you like you could run my TimeMachineLog add-on: http://www.readynas.com/forum/viewtopic.php?p=239030#p239030 and PM (Private Message) me the output. - tenneyAspirant
Many times since that upgrade.mdgm wrote: So that worked fine? You might want to contact NetGear tech support (http://www.readynas.com/support) and see if they have some suggestions.
On the phone now... - tenneyAspirantFYI - phone support useless; retried everything; no luck (no logs, nothing, just every backup deleted)
