Alex_CCIM
May 01, 2020Apprentice
Multi-Gig support for RN214 and RAX120
I have a RAX120 and RN214. Can I enable Multi-Gig support for my RN214 from my RAX120?
- May 05, 2020
I received the following response from Level 2 Technical Support:
Regarding the solution you propose, it would be irresponsible for Netgear to tell you that if it works and this has not been previously tested.
I've done some research, but the unit doesn't support USB network adapters.
But, If you create a bounded (LAG between the NAS and your router) will improve performance, and that is something that can be achieved,
in case you want to get higher transfer speeds, you will have to look for other ReadyNAS, because this NAS only supports speeds up to 1 gbit.
May 01, 2020Guru - Experienced User
The RN214 ethernet card doesn't support Multi-Gig. So unfortunately you can't do that.
