raelriggs
Jan 25, 2019Aspirant
My ReadyNas 2120v2 Diskless will not update past FW 6.9.0
Hi All, my first question here,
I have been using a RN2021 v2 for about 3 years give or take, I like the device and the features. I have 4no 4TB drives installed and have them in the normal X-Raid...
raelriggs
update,
i got the version number wron, my current version is 6.9.0 not 6.0.0. it was a typo.
Raelrigs
- StephenBJan 25, 2019Guru - Experienced User
Have you installed any apps (either from the admin web ui, or from using ssh)? If so, which ones?
Can you download the log zip file via the web ui?
Open volume.log and scroll to the end. Post what you see in these two sections (no need to go past the tempfs sections).
=== df -h === Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 3.7G 574M 3.0G 17% / tmpfs 1009M 0 1009M 0% /dev/shm tmpfs 1009M 532K 1009M 1% /run tmpfs 505M 656K 504M 1% /run/lock
=== df -i === Filesystem Inodes IUsed IFree IUse% Mounted on udev 187852 228 187624 1% /dev /dev/md0 1048576 12827 1035749 2% / tmpfs 188715 1 188714 1% /dev/shm tmpfs 188715 411 188304 1% /run tmpfs 188715 20 188695 1% /run/lock tmpfs 188715 9 188706 1% /sys/fs/cgroup
- raelriggsJan 28, 2019Aspirant
Hi StephenB
Thank you for your reply, sorry for the delay in my reply.
when i first installed the RN, I installed the GLPI program by Poussin version 1.0.0 (it is a Computer Asset Managment program) that i was looking to use in my workplace to manage our IT assets,
it did not work after it installed, so i uninstalled it. the uninstall failed, and im left with the programme in a half and half state. (this could be my problem)
my logs
i am logged in to the UI so have acces to logs that way,
i can SSH in as well but dont know the exact commands to type to get the logs.
from the UI i can download logs for all catagories, when i change to the volume log there is no content.
can you help me with the commands to get the log from the CLI
i was hoping to get this recified without having to pull a full reset because i have a huge amount of data on this NAS that would take forever to move off and back on again.
i thank you in advance for any help you can be.
Raelrigs
- StephenBJan 28, 2019Guru - Experienced User
That isn't unusual. But you do need to understand that RAID isn't enough to keep your data safe. If you don't have a backup on a different device, you will lose your data at some point.
# df // -i # df // -h
