kema
Aug 22, 2012Aspirant
My readyNAS duo is to slow. Please help!
Hi. I'm in way over my head here. I think my read / write speed has been too slow. Earlier I had a router only with G technology. I was told that I could expect twice as fast speed with a router with...
Aug 22, 2012Guru - Experienced User
I've tried the AC technology (with Netgear's R6300). In my home the 802.11ac connection didn't propagate very far, so I ended up running 802.11n bridging in most tests. Performance was still very good, but it is not wired gigabit.
If you want the best performance, connect the Duo to a wired gigabit network. When doing large transfers, connect your PC with ethernet to the same gigabit network.
