Traca
Jan 11, 2021Aspirant
NAS 312 Ethernet Port
Hi Community, My NAS 312 ethernet port stopped "working" after I performed a firmware upgrade few months ago. No lights come on anymore. I have tested the cables and all if fine.. it seems the p...
Traca
Thanks for your prompt reply!!
Answer to your questions below ***
What about the disk LEDs?
***the disk LEDs are on.
Have you tried both ethernet ports?
***Yes, tried both ports and no lights..
Any difference if you boot up without disks installed? If yes, then that may point to a disk issue or a power supply issue or some other hardware issue.
***I haven't tried, but I will try when I get to the office today.
Your disks could be moved to another x86 OS6 ReadyNAS e.g. RN422, RN424, RN524X, RN526X etc.
***is it a simple swapover or do I need to something else?
Thanks again
Jan 12, 2021Guru - Experienced User
It's a simple swapover.
Though it is reasonable to check out the replacement before migrating the disks - especially if you get something used. You can do that by doing a factory install on a spare disk (not part of the array). Then make sure the NAS boots with that disk in every slot. Also, make sure the firmware is up to date.
- TracaJan 12, 2021Aspirant
Thanks stephen,
I'm a bit confused.. So if I buy a used unit I can't just slot the 2 disks in there and run it, I'll need to factory reset it and update the firmware using separate disks? Can't I reset it and update the firmware without having disks in there?
I am worried if I slot my disks in the new unit then it might wipe everything!!
- StephenBJan 12, 2021Guru - Experienced User
You could just migrate the disks. I'm suggesting testing the used NAS first with a spare disk, because I think that is something is wrong with it, it would be safer to test it with a spare disk.
No, that is actually not possible. There is no way to update the flash install image w/o a disk in place - and a factory reset cannot be done w/o at least one disk installed in the NAS. A factory reset installs the firmware in the flash onto the disk(s).
If the array is healthy, then that shouldn't happen. Since you are running RAID-1, you could try migrating just one disk - then you'd have the other in reserve. If you do that, then boot up the NAS in read-only mode, and check that the data is there. Then power down, insert the second disk, and boot up normally.
