Traca
Jan 11, 2021Aspirant
NAS 312 Ethernet Port
Hi Community, My NAS 312 ethernet port stopped "working" after I performed a firmware upgrade few months ago. No lights come on anymore. I have tested the cables and all if fine.. it seems the p...
mdgm
Jan 11, 2021Virtuoso
What about the disk LEDs?
Have you tried both ethernet ports?
Any difference if you boot up without disks installed? If yes, then that may point to a disk issue or a power supply issue or some other hardware issue.
If no, then I think it probably points to an issue with the ethernet port. You could try booting into tech support mode to see if there's any difference.
Your disks could be moved to another x86 OS6 ReadyNAS e.g. RN422, RN424, RN524X, RN526X etc.
Assuming it's failure of the NICs if you are comfortable with shell commands you could hook up a HDMI monitor to the RN312 and a USB keyboard and a USB storage device and copy data off that using that, I think.
Traca
Jan 12, 2021Aspirant
So I think I know what the problem is.. we had a power spike few weeks ago due to lightening stricked nearby. This causes the eathernet ports at the router and the NAS to break.
I am surprised through that the 2 NAS ethernet ports are not working.. I would have thought only one of them should stop working and the other be still operational.
- mdgmJan 12, 2021Virtuoso
Both the ethernet ports are on the same board so if one is taken out by a power spike it's almost certain the other one will as well.
You could move the disks to a new ReadyNAS or alternatively you could attempt to recover data from an ordinary x86 Linux PC or even using 3rd party software for WIndows such as ReclaimMe.
