Traca
Jan 11, 2021Aspirant
NAS 312 Ethernet Port
Hi Community, My NAS 312 ethernet port stopped "working" after I performed a firmware upgrade few months ago. No lights come on anymore. I have tested the cables and all if fine.. it seems the p...
mdgm
Jan 11, 2021Virtuoso
What about the disk LEDs?
Have you tried both ethernet ports?
Any difference if you boot up without disks installed? If yes, then that may point to a disk issue or a power supply issue or some other hardware issue.
If no, then I think it probably points to an issue with the ethernet port. You could try booting into tech support mode to see if there's any difference.
Your disks could be moved to another x86 OS6 ReadyNAS e.g. RN422, RN424, RN524X, RN526X etc.
Assuming it's failure of the NICs if you are comfortable with shell commands you could hook up a HDMI monitor to the RN312 and a USB keyboard and a USB storage device and copy data off that using that, I think.
Traca
Jan 27, 2021Aspirant
Do you have any idea on how to use the shell commands to backup to an external hard drive?
- StephenBJan 27, 2021Guru - Experienced User
Is the USB drive mounted?
You can copy files using the linux command. https://man7.org/linux/man-pages/man1/cp.1.html
for instance
# cp -R /data/sharename /usbvolume/sharename
- TracaJan 27, 2021AspirantIt’s just an external hard drive, do I need to do anything to mount it?
What is this so complicated?!! I just want to move my disks to anther nas as the Ethernet ports died in me..- StephenBJan 27, 2021Guru - Experienced User
Traca wrote:
I just want to move my disks to anther nas as the Ethernet ports died in me.Is this another ReadyNAS? If so, what model is it? Direct migration of disks is possible if you are wanting to move the disks to another ReadyNAS running OS-6.
Traca wrote:
What is this so complicated?!!It's complicated because you don't know linux, and you are limited to using the linux command line.
What would have made it simple: having a proper backup plan in place for your data. RAID isn't enough to keep it safe.
Traca wrote:
It’s just an external hard drive, do I need to do anything to mount it?Normally the NAS would mount it automatically, though that depends how it is formatted.
Part of the puzzle here is finding the path to the USB drive in linux, as you need that in order to use the CP command in the earlier post.
Try typing
# lsblk
Ignore any output that includes sda or sdb - these are the internal drives in your NAS. If the drive is mounted, you will see another device in the list (probably sdc). That would show you the mount point for that drive (the rightmost entry on the list).
If that is too confusing, you can take a photo of the output, and post it here.
