godders7
Jul 24, 2018Aspirant
NAS DUO RND2110
I updated the software several months ago now when I go on the web through setup to check out the condition of my nas I just get the front page with no active buttons. see pic
- Jul 24, 2018
One cause of this problem is a filling OS partition. This is not the same as the data partition - it is a 2 GB partition on the disks that runs linux and the ReadyNAS application. If that's the cause, then your NAS will eventually lock up completely.
The first thing to do is back up all your files on an different device (a USB drive for instance).
After that you can try to get the admin page running again.
- reboot the NAS, and see if the problem disappears. If it does, clear the logs from the web ui.
- contact paid support (my.netgear.com), and have them resolve it remotely.
- If ssh is enabled, then connect to the NAS with ssh, and see if the OS partition is full.
- do a factory reset, reconfigure the NAS and reload the data from backup.
godders7
I can access my files but it looks to me as if when I updated the OS desktop of the nas was corrupted, which means I am locked out of the OS of the nas. Fortunatly I can still store on it and stream my music.
Jul 24, 2018Guru - Experienced User
