TimCD
Oct 15, 2018Aspirant
Nas Duo RND2150
I have an older Nas Duo, it was working fine and then suddenly was not accessible. I’m pretty sure I lost both drives, my fault, it had stopped e mailing me status and I had not been checking it. I’m...
- Oct 16, 2018
The part number is RND4TRAY1-10000S, which might help googling. They are hard to find. Newer trays have a square latch button, the older design with the circular button tended to jam. Both will work.
Trays for the NV+, Duo, Ultra, and Pro desktop NAS are all interchangeable. OS 6 NAS use a different tray design, as do rackmount ReadyNAS.
Oct 15, 2018Guru - Experienced User
You might not have mounted the C volume correctly.
There are instructions here: http://jim-st.blogspot.com/2012/07/mouning-readynas-drives-on-x86-systems.html
- TimCDOct 15, 2018Aspirant
Thanks for info. I thought it was going to work, but the drive seems to be bad. I have it in a dock and the dock starts beeping and sounding error beeps for bad drive. I can look into some folders, others causes the thing to go nuts. As you can see from the attached, it isn't able to get into the C. It looked like is was going to work, but I think it just can't read the drive.
Thanks,
Tim
- StephenBOct 16, 2018Guru - Experienced User
If you have a windows PC, try testing the second drive with the vendor diagnostic (seatools for seagate, lifeguard for western digital). If the drive is healthy, the NAS should boot up with only that drive in place (in the original slot if you remember it).
You could try cloning one of the disks if it is marginal, but I suspect it's too late for that with the disk you are working on now.
- TimCDOct 16, 2018Aspirant
Thanks, I'll give your suggestions a try.
Tim
