TimCD
Oct 15, 2018Aspirant
Nas Duo RND2150
I have an older Nas Duo, it was working fine and then suddenly was not accessible. I’m pretty sure I lost both drives, my fault, it had stopped e mailing me status and I had not been checking it. I’m...
- Oct 16, 2018
The part number is RND4TRAY1-10000S, which might help googling. They are hard to find. Newer trays have a square latch button, the older design with the circular button tended to jam. Both will work.
Trays for the NV+, Duo, Ultra, and Pro desktop NAS are all interchangeable. OS 6 NAS use a different tray design, as do rackmount ReadyNAS.
Oct 15, 2018Guru - Experienced User
You might not have mounted the C volume correctly.
There are instructions here: http://jim-st.blogspot.com/2012/07/mouning-readynas-drives-on-x86-systems.html
TimCD
Thanks for info. I thought it was going to work, but the drive seems to be bad. I have it in a dock and the dock starts beeping and sounding error beeps for bad drive. I can look into some folders, others causes the thing to go nuts. As you can see from the attached, it isn't able to get into the C. It looked like is was going to work, but I think it just can't read the drive.
Thanks,
Tim
