TimCD
Oct 15, 2018Aspirant
Nas Duo RND2150
I have an older Nas Duo, it was working fine and then suddenly was not accessible. I’m pretty sure I lost both drives, my fault, it had stopped e mailing me status and I had not been checking it. I’m...
- Oct 16, 2018
The part number is RND4TRAY1-10000S, which might help googling. They are hard to find. Newer trays have a square latch button, the older design with the circular button tended to jam. Both will work.
Trays for the NV+, Duo, Ultra, and Pro desktop NAS are all interchangeable. OS 6 NAS use a different tray design, as do rackmount ReadyNAS.
TimCD
Oct 16, 2018Aspirant
Brilliant, it booted with just the one drive, I guess it's the parity drive. It's the one I could not see any files on when connected to my Linux box. The other dirve I could see the file structure, but it was very corrupt and I could not mount the C drive as instructed, or access it without the dock it was in beebing a death code.
It looks like I will be able to recover my files. I had some backups, but there was a lot on the NAS that I wasn't sure I had backed up. I better do a better job of backing up.
I'm copying the files now before I install a new drive and let it rebuild.
One thing, do you know if I can get new drive bays. When I opened them, the little plastic catches broke. It is pretty old, but it would be nice to keep using it.
Thanks for the help!
Cheers,
Tim
Oct 16, 2018Guru - Experienced User
- TimCDOct 16, 2018Aspirant
Thanks Stephen,
You were a big help. I was about to give up, but you kept me going with your advice. I'm coping all the files off the NAS and it is going well. It would have been a bit of a loss if I could not have recovered them, so I than you very much. I will close this out now.
Cheers,
Tim
