FG
Dec 08, 2017Aspirant
NAS Mirror
Currently I have 1 ReadyNAS RN2120v2. We had a recent failure on site and lost all 16TB on the NAS. Looks like a 3138 would be close match to the 2120. 3138 is probably a little faster. I wan...
FG
Dec 29, 2017Aspirant
Marc_V
Thank you for the info.
In the link below, step #9, in the remote settings, once I choose the Remote: Rsync Server for the protocol the PORT field is displayed. What port should I use. Step 9 does not show a port field.
I am trying to back up one nas to another.
On the admin page of MainNAS, under System - Settings. Rsync service is NOT enabled. The instructions did not say to do this.
On the admin page of BackupNAS, under System - Settings. Rsync is enabled
Marc_V
Dec 29, 2017NETGEAR Employee Retired
Hi FG
Rsync can be disabled on the MainNAS since the procedure is to push the data to BackupNAS.
Port being requested for RSYNC should be Port 873, please take note that you may have to configure port forwarding on your router.
following the article I am sure will get us through the backup configuration. Please let me know once everything has been set.
Happy New year!
Regards
- FGDec 29, 2017Aspirant
This may be a "dumb" question, but it both MainNas and BackupNas are plugged into same switch, then I wouldn't need to mess with the router, correct?
Port forwarding may be if one NAS was offsite?
- Marc_VDec 29, 2017NETGEAR Employee Retired
If they are on the same network then the answer is Yes. No need to setup port forwarding but you still have to put in the port number on the NAS backup configuration
Hope this helps!
Regards
