mertician
Mar 08, 2013Aspirant
NAS not responding after reboot when new drives installed
I added 2x3TB drives to my 1x2TB NV+ v2. It took about 5 hours for the 'Recovery' process and about a day for the next step (can't remember what it was, something like Reshape). I checked on the Front...
Mar 08, 2013Guru - Experienced User
You should open a support case at "support.netgear.com" just in case.
Usually the NAS will respond (albeit sluggishly) during expansion. And no LED activity is worrysome.
BTW, your math is correct, you should have ended up with a 5 TB volume (~4.6 in the base-2 units the NAS uses). There is a ReadyNAS calculator here: http://kossboss.siigna.net/xraid.html
