DeadNAS
Dec 12, 2017Aspirant
NAS RN102 wakes up every month
After update to version 6.8.0. my NAS starts every month by it self. In log it looks like: Wed Dec 6 2017 6:00:06 System: ReadyNASOS background service started.
Mon Nov 6 2017 4:38:16 System: Re...
yxue
Apr 20, 2018NETGEAR Expert
Have you ever enabled Power Timer?
tytou
Apr 20, 2018Aspirant
Hello,
because I had this issue, I have setup power-up/off schedule and deactivated it after because this was a proposed workaround, but before the issue happened, I have never used this feature. This is disabled since years now.
I use the NAS as most of the time powered off, and power it on 'on demand'. I usually use WoL for that because I can do it w/o using the physical buttton, and because from time to time I need to use it when away from home.
But, I'd prefer the NAS not to power on itself regularly.
I went to my email, because I receive an email from the NAS each time it has an administrative event (f/w update available, power(-off etc...).
Unfortunately I didn't keep all the emails, but from theones I still have I can tell you that the NAS is powering on alone
in 2017: 03/30,04/26,05/26,06/26,07/15,08/17,09/30,...,11/04,12/08
in 2018: 01/08,02/10,03/14,04/14...
in the past (2016 it was each month on the 29th at 22:00 local time
Cheers,
