Serians
May 27, 2014Aspirant
NAS to NAS Rsync Backup
Hi, need help for configuring the rsync backup between 2 RN314. It doesnt work with any parametres. If in path for destination i put nothing then it can't find module name, if i put the share name, t...
TonV
Did you enable RSYNC on the boxes AND on the shares?
Then on NAS1 you could create a backup job with source "Backup" (type "share")
and destination type "remote", Host: NAS2 and path "target" (if that is the name of the destination folder)...
Hope this helps,
Ton
Hope this helps,
Ton
