bedlam1
May 30, 2017Prodigy
Rsync Backup job NAS to USB drive suddenly displaying strange behaviour
The backup job in question has been running flawlessly 3 times a day for the last year.(alongside a similar job which is not mis-behaving)
The only change I have made since this began is installing OS 6.7.4
The settings are:
The Source Type is "volume" and the Name is "volume: data" Everything else is blank.
The Destination is Type "remote" and the Name is "remote: RSync Server", Host is "localhost" and Path is "USB_HDD_1/NAS_IAN_Backup"
Under Advanced compression is disabled and Remove deleted files on target is checked.
The USB Drive is NTFS format.
The odd behaviour is as follows:
The log shows the log as starting and completing within one second !!! and reports Backup Status: Success
Which is clearly not correct.
The log also shows the following:
sending incremental file list
sent 733 bytes received 41 bytes 1,548.00 bytes/sec
total size is 2,930 speedup is 3.79
S): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/Documents, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/Downloads, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/Ians_Stuff, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/Music, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/PC_Backup, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/Pictures, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/Recovered_Data, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/Transmission, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/Videos, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/couchpotato, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/sickrage, ACL_TYPE_ACCESS): Operation not supported (95)
data/Documents/
data/Downloads/
data/Ians_Stuff/
data/Music/
data/PC_Backup/
data/Pictures/
data/Recovered_Data/
data/Transmission/
data/Videos/
data/couchpotato/
data/sickrage/
sent 838 bytes received 1,308 bytes 4,292.00 bytes/sec
total size is 2,930 speedup is 1.37
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1183) [sender=3.1.1]
I am totally stumped by this and am hoping someone here can help me or better still provide a solution
Did you check the permissions and owners for these particular MP3s? Right-click in file explorer, etc...
- crazy_toyNETGEAR Expert
Hi badiam1
I dont understand job's setting , destination is 'remote' , host should be remote server host , not localhost
Could you please paste settings' screenshot?
Thanks
He's backing up to a locally connected USB drive using rsync, so the "remote" destination has to use localhost.
It'd be far more direct if you could specify rsync with local source and local destination, but you can't do that.
- bedlam1Prodigy
That's exactly correct @StephenB
Shame Netgear "experts" don't know that
Am still hoping for someone more knowledgeable to help withe the ACL problem
