Serians
May 27, 2014Aspirant
NAS to NAS Rsync Backup
Hi, need help for configuring the rsync backup between 2 RN314. It doesnt work with any parametres. If in path for destination i put nothing then it can't find module name, if i put the share name, t...
ephemeris
Jun 10, 2014Aspirant
This is a little disturbing...
Something has been messed up. When you set up the backup job in FrontView, the only acceptable syntax for the Path to a share on another ReadyNAS appears to be
::yoursharename\
Now that is clearly NOT what the documentation and the Help button say. If you do this, FrontView claims its okay and reports the destination as
yourreadynasname.local::::yoursharename\
I'm pretty sure that the 4 colons in a row syntax is not right, but when I did a configuration save and looked at the backup jobs file, that is what it saved. I'm not sure how much more I want to experiment with this until a Jedi weighs in.
::yoursharename\
