mvee's avatar
mvee
NAS won't turn on
`NAS won;t trun on. When I plug it in and switch it on, the lights stay on for 2 secs and the machine seems like it is trying to turn on. Then it abruptly stops. Unplugging power supply and reconnect...
  • JohnCM_S's avatar
    JohnCM_S
    Nov 03, 2018
    Hi mvee,
    In case you will still have the same behavior after removing the drives, the issue is most probably with the chassis itself. If you are the original purchaser of the device and it is still under the hardware warranty, you may contact support then so they can process an RMA for the chassis
ProSupport for Business
