sidestick
Aug 10, 2015Aspirant
NAS104 not connecting OSx nor able to access via RemoteNAS
Hi ALL 1st time here. I am trying to use the NAS104 as personal cloud but until now it turned to be a externa hard drive that I can send my files in but have a LOT of trouble trying to connec...
Aug 10, 2015Guru - Experienced User
OpenVPN might work better for you.
- sidestickAug 10, 2015Aspirant
Tks for you quick reply
Sorry for the question, but can you give me some orientation on how to configure an OpenVPN?
I am really a dumb on the matter :(
- StephenBAug 10, 2015Guru - Experienced User
Some Netgear routers (perhaps other models) have OpenVPN support built in (the R7000 is one). That's by far the easiest. Once configured, you run the OpenVPN client on the PC, and then you have full access to your home network - NAS, printers, other devices. The connection is encrypted with AES, and if it is in the router doesn't require opening any ports. I don't think there is an OpenVPN app for the RN104.
OwnCloud is similar to ReadyCloud - I haven't used it, so I don't if it has the same issues for you or not. There is a small charge from the app developer (and it is available on the RN104).
IMO, ReadyCloud still isn't there yet.
I am using a MacBook Pro and soon an iMac and also would like that my wife MBP could have access to the files also...
Nowadays only I have access and via browser... Really frustrating.
My router is one that the service provider lend - a Technicolor TC7300. For WiFi I use a Airport Extreme Router w/ 3TB.
Is there a possible way to configure an openVPN with this hardware?
Why is so dificult to access the files locally?
Is there a way I can connect cable and use it as an external drive? (Not the way it should be used but I really need access to those files)
Tks
