sidestick
Aug 10, 2015Aspirant
NAS104 not connecting OSx nor able to access via RemoteNAS
Hi ALL 1st time here. I am trying to use the NAS104 as personal cloud but until now it turned to be a externa hard drive that I can send my files in but have a LOT of trouble trying to connec...
sidestick
Tks for you quick reply
Sorry for the question, but can you give me some orientation on how to configure an OpenVPN?
I am really a dumb on the matter :(
Aug 10, 2015Guru - Experienced User
Some Netgear routers (perhaps other models) have OpenVPN support built in (the R7000 is one). That's by far the easiest. Once configured, you run the OpenVPN client on the PC, and then you have full access to your home network - NAS, printers, other devices. The connection is encrypted with AES, and if it is in the router doesn't require opening any ports. I don't think there is an OpenVPN app for the RN104.
OwnCloud is similar to ReadyCloud - I haven't used it, so I don't if it has the same issues for you or not. There is a small charge from the app developer (and it is available on the RN104).
IMO, ReadyCloud still isn't there yet.
