offbyone
Nov 30, 2014Aspirant
NAS104 Raid decision? Xraid vs Raid 10 etc #24296869
I just got a NAS 104 and installed 4 3TB Western Digital Red disks. Since I bought all my drives I don't really plan to upgrade or mess with the drives in the near future. When I powered up and ...
mdgm-ntgr
Nov 30, 2014NETGEAR Employee Retired
For expandability X-RAID is best. But if you don't intend to expand your volume in the future with 4TB disks (max capacity on compatibility list for the 104) then you don't need X-RAID.
You can disable X-RAID, delete the existing volume and create a new RAID-10 one if you like.
I would recommend that you still call the volume "data" (no quotes and note the case).
