netghiro's avatar
netghiro
nasready 312 and JBOD / no RAID setup
Hi, I'm thinking of buying a readynas 312 unit. I was just wondering can I install in it 2 different drives (a 4TB drive and a 8TB) and use them as 2 different btrfs volumes? Maybe I'm not using t...
  • Danthem's avatar
    Aug 14, 2015
    Shouldn't be any problems, just disable xraid from the volumes tab, then create two separate volumes and you're good to go :-)
    Edit; Not sure if the 312 can handle any 8TB drives though - on the official compatibility list there's only a 6TB drive, WD RED WD60EFRX.
ProSupport for Business
