network23
Mar 17, 2013Aspirant
Need help getting permission to save to USB EXT3 drive
I've been having some troubles with my NV+ and need to back it up before doing a factory reset. Transferring files over the network is too slow (1-3MB/sec) and I thought directly connecting a USB driv...
Mar 21, 2013Guru - Experienced User
Yes. NTFS transfers will be slower, so this may only be helpful as a test.
network23 wrote: ...Are you saying, plug the drive into my PC, format it there, and then try to connect it directly to the NV+ and attempt to transfer the files via the Frontview Backup functionality?
Do you have files > 4GB? If not, you could alternatively use fat32.
- Jan 17, 2024Retired_Member
