jmel's avatar
jmel
Need help recovering from bad firmware update on readynas102
I have an older readynas that had 6.1.1 on it. I tried updating to latest firmware manually - via the web page menu. Afterwards, it will no longer boot up. Raidar does not see it.I tried USB recovery...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Nov 26, 2016
    USB Boot Recovery didn't work as your USB key had no partition table on it. The system is able to boot off the USB key, but when it looks for the first partition on the USB key to mount it's unable to find one.
    Your system should now be fixed.
ProSupport for Business
