NetworkedinPA
Jan 22, 2015Aspirant
Need help selecting backup/RN features #24580559
Ok, I am having some difficulty translating RN features into function ;) I have ReadyNAS 316 16TB RAID6 in XRAID2 mode. I have created some shares and mapped a windows 7 drive to backup a bunch ...
Jan 22, 2015Guru - Experienced User
After you sign in at https://readycloud.netgear.com you will see a "get the readynas app for backup and sync" at the lower left. If you are using your win7 system and click on that, it will download the readycloud softwware for windows.
After you install that, there will be a readycloud icon in your system tray, and it will also be in "all programs" in the Netgear ReadyNAS folder.
