christopher2
Dec 04, 2012Aspirant
Need help w/ReadyNAS SAMBA configuration
A change Netgear made as they upgraded RAIDiator 4.2.20 to 4.2.22 (for Intel) and 4.1.8 to 4.1.10 (on Sparc) was to change the SAMBA configuration in a way that stops older CIFS clients from accessing...
christopher2
Dec 14, 2012Aspirant
OK. I've set log level to 10, but I don't see the ARCH identified in the log messages. Here are the entries from /var/log/samba/log.smbd. Is someone able to point me at the ARCH value?
[2012/12/14 17:34:43.742020, 2] smbd/reply.c:554(reply_special)
netbios connect: name1=DATA 0x20 name2=ATRON001E7E 0x0
[2012/12/14 17:34:43.742188, 2] smbd/reply.c:565(reply_special)
netbios connect: local=data remote=atron001e7e, name type = 0
[2012/12/14 17:34:43.748302, 2] param/loadparm.c:7951(do_section)
Processing section "[printers]"
[2012/12/14 17:34:43.748753, 2] param/loadparm.c:7951(do_section)
Processing section "[Negatives]"
[2012/12/14 17:34:43.748839, 2] param/loadparm.c:6937(service_ok)
Enabling strict allocate on service Negatives
[2012/12/14 17:34:43.748859, 2] param/loadparm.c:6941(service_ok)
Setting allocation roundup size to 100MB on service Negatives
[2012/12/14 17:34:43.748876, 2] param/loadparm.c:7951(do_section)
Processing section "[PC_Setup]"
[2012/12/14 17:34:43.748961, 2] param/loadparm.c:6937(service_ok)
Enabling strict allocate on service PC_Setup
[2012/12/14 17:34:43.748980, 2] param/loadparm.c:6941(service_ok)
Setting allocation roundup size to 100MB on service PC_Setup
[2012/12/14 17:34:43.748997, 2] param/loadparm.c:7951(do_section)
Processing section "[TPI_Archive]"
[2012/12/14 17:34:43.749132, 2] param/loadparm.c:6937(service_ok)
Enabling strict allocate on service TPI_Archive
[2012/12/14 17:34:43.749152, 2] param/loadparm.c:6941(service_ok)
Setting allocation roundup size to 100MB on service TPI_Archive
[2012/12/14 17:34:43.749170, 2] param/loadparm.c:7951(do_section)
Processing section "[backup]"
[2012/12/14 17:34:43.749253, 2] param/loadparm.c:6937(service_ok)
Enabling strict allocate on service backup
[2012/12/14 17:34:43.749272, 2] param/loadparm.c:6941(service_ok)
Setting allocation roundup size to 100MB on service backup
[2012/12/14 17:34:43.749289, 2] param/loadparm.c:7951(do_section)
Processing section "[media]"
[2012/12/14 17:34:43.749390, 2] param/loadparm.c:7388(handle_include)
Can't find include file /etc/frontview/samba/Shares.conf.
[2012/12/14 17:34:43.749436, 2] param/loadparm.c:6937(service_ok)
Enabling strict allocate on service media
[2012/12/14 17:34:43.749454, 2] param/loadparm.c:6941(service_ok)
Setting allocation roundup size to 100MB on service media
[2012/12/14 17:34:43.749472, 2] param/loadparm.c:7951(do_section)
Processing section "[homes]"
[2012/12/14 17:34:43.751407, 2] lib/interface.c:340(add_interface)
added interface LeafNets ip=fe80::f4d9:31ff:febd:c27f%LeafNets bcast=fe80::ffff:ffff:ffff:ffff%LeafNets netmask=ffff:ffff:ffff:ffff::
[2012/12/14 17:34:43.751466, 2] lib/interface.c:340(add_interface)
added interface LeafNets ip=5.177.191.20 bcast=5.255.255.255 netmask=255.0.0.0
[2012/12/14 17:34:43.751490, 2] lib/interface.c:340(add_interface)
added interface eth0 ip=10.10.1.8 bcast=10.10.1.255 netmask=255.255.255.0
[2012/12/14 17:34:43.765250, 2] smbd/sesssetup.c:1417(setup_new_vc_session)
setup_new_vc_session: New VC == 0, if NT4.x compatible we would close all old resources.
[2012/12/14 17:34:43.766127, 2] auth/auth.c:314(check_ntlm_password)
check_ntlm_password: Authentication for user [atron] -> [atron] FAILED with error NT_STATUS_WRONG_PASSWORD
[2012/12/14 17:34:43.782783, 2] smbd/sesssetup.c:1417(setup_new_vc_session)
[2012/12/14 17:34:43.783301, 2] auth/auth.c:314(check_ntlm_password)
