ilker26266
Jun 13, 2016Aspirant
Net Gear ReadyNAS RN10400 ERR:could not mount boot flash
Hi all , Could you help us pls ? I have a Netgear RN10400 device . But when I open the device, I get the error "ERR:could not mount boot flash" on my lcd . I ran from the Netgear forums. I ...
BrianL2
Jun 13, 2016NETGEAR Employee Retired
Hi ilker26266,
Try with another USB flash drive using the steps here. If this won't work, insert a spare disk in your system set it up (update to the latest Firmware *optional*) and once setup, turn off the unit and re-insert your original disks. Take note that if you will do this procedure, the original disks should be inserted in the same order or in its original bay.
Kind regards,
BrianL
NETGEAR Community Team
