chrstr
Mar 05, 2013Aspirant
NETGEAR NV+ not booting, stuck on “Booting … Quota chk: 0,7%
I have an NV+ with 4 x1TB disks that dropped off the network after some changes to the sub domain set-up in the network.
I tried to reboot it with the power button but it didn’t respond. The LCD panel didn’t light up as is should do and the NV+ seemed to be ‘dead’ even though all the four disk LEDs where green.
In order to force a restart the power was shut off. Now the NV+ will not boot, the LCD says “Booting … Quota chk: 0,7%”. The four disk LEDs are green and the power LED is solid blue.
RAIDar is not detecting the NV+ on the network.
Please advise on what to do.
/chrstr
/chrstr
- RabbieAspirantNeed to boot to "Tech support" mode for netgear support engineer.
You can have a phone to netgear local support(the call center) for help.
Also can PM me the remote host(wan ip address) when you boot the nas to "tech supprot" mode and forward the port 23 to internet. - chrstrAspirantThanks Rabbie,
how do I boot to "Tech support" mode?
How do I forward port 23 to Internet?
/chrstr - StephenBGuru - Experienced User
chrstr wrote: how do I boot to "Tech support" mode?
Instructions for each readynas model are here: http://www.readynas.com/kb/faq/boot/how ... _boot_menu
You do this in your router. Exact procedures vary, but if you google your router model number you will likely find a guide.chrstr wrote: How do I forward port 23 to Internet? - chrstrAspirantThanks I will try this.
/chrstr
