Rafael_Luz
Aug 20, 2018Aspirant
NetGear ReadyNas 2120 Upgrade Issue from 6.1.6 to 6.8.0
Hi All,
I have a problem with my storage after trying to update it from 6.1.6 to 6.8.0. I simply lost access to the admin webpage and the NAS is not pingable anymore. I don't wanna do a factory...
- Aug 21, 2018
Rafael_Luz wrote:
Which firmware should I use, as I don’t want to lose any data, I do prefer to make sure I am going to use the right oneI suggest following the release notes :smileywink:
"They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then onto 6.9.x."
So try using 6.2.5 in the USB recovery. When the NAS comes back, then upgrade to 6.5.2, and then finally 6.9.3. I see no good reason to stop at 6.8.0.
Rafael_Luz wrote:
Which firmware should I use, as I don’t want to lose any dataHopefully you have a backup (and simply want to avoid the inconvenience of rebuilding the NAS and restoring the data). RAID isn't enough to keep your data safe.
That said, this process shouldn't be destructive. If you want to be particularly safe, you could remove the disks (labeling them by slot), and insert a single blank disk. After a successful USB recovery, the system would do factory install to the blank disk. You'd then power down, restore the original disks to their original slots, and then boot up again. The system should then install 6.2.5 onto the disks.
bedlam1
Aug 20, 2018Prodigy
You need to read the Warnings on the ReadyNAS OS V6.9.3 Release Notes: HERE
I can't over you a solution but I am sure someone else will chime in
Rafael_Luz
I've read the warning before, and there was nothing related to not upgrade from 6.1.6 to 6.8.0. I've seen some that was showing the warnings so I didn't go to those upgrades..
- bedlam1Aug 20, 2018Prodigy
The warning has been on all Release Notes since 6.5.2, circa September 2016
- mdgm-ntgrAug 20, 2018NETGEAR Employee Retired
What's done is done.
Yes, you'll need to use USB Boot Recovery to fix this.
Note that not all USB keys are compatible.
Your USB key should be formatted with a single FAT32 partition using the MBR partitioning scheme.
Let us know how you go with this.
- Rafael_LuzAug 21, 2018AspirantHi,
Should I use the 6.1.6
Or the same I tried to update (6.8.0)?
After the restore, will I get the same config I had before? Because the network the storage is in, doesn’t have DHCP and the doc says if it doesn’t find any DHCP it gets de APIPA address which I find horrible instead of having an default IP- StephenBAug 21, 2018Guru - Experienced User
