shahrouq
Sep 09, 2019Aspirant
Netgear ReadyNAS 214 goes offline after 1 hour
Hi All, I am using netgear ReadyNAS 214 4*2 TB since Dec 2017 and all was working fine . But suddenly last month i.e August the ReadyNAS 214 is not reponding but i can ping the device and i get r...
Sep 09, 2019Guru - Experienced User
Are you getting into the web ui at all? Or did you get that info via ssh?
What status is RAIDar seeing for the NAS? https://kb.netgear.com/20684/ReadyNAS-Downloads
Perhaps post the screen shot (png format at full resolution please).
- shahrouqSep 09, 2019Aspirant
I am not getting web ui at all, but when i unplugged and replug the Power cord it starts for almost 1 hour in that time i downloaded all the logs from it.
- StephenBSep 09, 2019Guru - Experienced User
How did you download them?
What status is RAIDar giving you? https://kb.netgear.com/20684/ReadyNAS-Downloads
- shahrouqSep 09, 2019AspirantIf you go in logs section, there is button to download all logs, from there we can download it.
Do you know any solution for the problem which is mentioned above?
