Nastyman79
May 07, 2018Aspirant
Netgear Readynas Duo RND2110 V2 factory reset
I purchased a second hand Netgear Readynas Duo v2 off Ebay, I have attempted to factory reset as I do not know the logon details, I get the 2 drive lights to flash on three times in a row then the dr...
- May 07, 2018
The process for doing a reset is different for different platforms, so let's start by confirming the model. The labeling is confusing, and many v1 owners mistakenly believe they have a v2.
A v1
- runs 4.1.x firmware
- has a part number on the back that ends with -100xxx (xxx is either NAS or a country-specific code)
- might have a label on the back that says v2 (the source of the confusion).
A v2
- runs 5.3.x firmware
- has a part number on the back that ends with -200xxx
- says v2 on the front chassis
Let us know which is these models you purchased,
Nastyman79
It apperas to be a V1 so have started a factory reset using the instructions provided and will try to login after that has finished.
May 07, 2018Guru - Experienced User
Let us know how it goes.
Your v1 is an old device (Netgear stopped manufacturing them in 2011). The max disk size it can handle is 2 TB. Another limitation is that it uses SMB 1.0 - which is being deprecated by Microsoft. You can however still install the client on Windows 10.
- Nastyman79May 07, 2018Aspirant
Now able to login, thanks for the help.
