Pyronought
Mar 26, 2019Aspirant
NETGEAR RN10200 - No idea
New to NAS,
Have a ReadyNAS 102, which i had set up 3 years ago, and just left running in my cabinet.
I would like to reuse it, however i cannot talk to it outside of RAIDar, and even then it...
Pyronought
Followed Guides
https://community.netgear.com/t5/Storage-Central/RESET-NAS-RN102-TO-Factory-settings/td-p/408607
https://kb.netgear.com/22892/How-do-I-access-the-boot-menu-on-my-ReadyNAS-102-202-212-or-312
Unit is connected difect to my Laptop at the moment, ideally it would be connected to wider network, via NETGear hub, or into a Booster unit, or direct into the main Router.
Connectd to my Laptop at the moment as i just want it working first before i add it into the network system.
Remeber your talking to a NAS gear noob, spell it out, cryon and big letters style.
Mar 26, 2019Guru - Experienced User
It's easier if you connect the NAS directly to your router. So I suggest starting there instead of connecting it directly to your laptop.
- PyronoughtApr 08, 2019AspirantClarification router or computer? Statement says router instead of router.
Is there a way to hard reset the unit to start again with it?- SandsharkApr 08, 2019Sensei
Connect to router so it and your computer are automatically assigned IP addresses in the same subnet (assuming you didn't previously have it connected to a router with a different subnet and set it for a fixed IP).
An OS re-install (not a Factory Default) will reset the password and DHCP settings but not harm the data. But it's a bit tricky on a unit without a display panel.
- StephenBApr 08, 2019Guru - Experienced User
Pyronought wrote:
Clarification router or computer? Statement says router instead of router.Sorry, I fixed the typo.
Pyronought wrote:
Is there a way to hard reset the unit to start again with it?Yes. There is a factory default boot option that reformats the disks (and of course destroys your data). There'a also the OS reinstall that Sandshark mentioned - which is non-destructive. I agree it's a bit tricky with no LCD display. You can also zero the disks (connecting them to a PC and using Seatools or WDC's Lifeguard software). Then reinsert them into the NAS and power up - that will force a fresh factory install.
The boot menu options for your NAS are described on pages 20-21 of the hardware manual ( http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf )
A full zeroing isn't usually needed, just use Disk Management to delete all the partitions.
