Czrik84
Aug 03, 2017Aspirant
NetGear RN10200 no network link
Hi, I've been using my NAS for a while now and today I noticed I couldn't connect. After some tests, I realised that there is no network link. Tested multiple cables, ports, even direct connecti...
- Aug 04, 2017
Thanks, Stephen!
I did that, no luck. So I decided to open it and check for any signs of burn damage as I cam home the other day and the master fuse on the apartment was blown. I took out the network and USB card and put it back in. Success! The LED for traffic was on and it's working like a charm now. Thanks for your help!
Aug 03, 2017Guru - Experienced User
Yet another option is to remove the disk altogether, and see if RAIDar sees the NAS.
The warranty is 3 years for the original purchaser, you can check warranty coverage (and arrange for an RMA if you are covered) at my.netgear.com.
- Czrik84Aug 04, 2017Aspirant
Thanks, Stephen!
