Czrik84's avatar
Czrik84
NetGear RN10200 no network link
Hi,   I've been using my NAS for a while now and today I noticed I couldn't connect. After some tests, I realised that there is no network link. Tested multiple cables, ports, even direct connecti...
  • Czrik84's avatar
    Czrik84
    Aug 04, 2017
    Thanks, Stephen!
    I did that, no luck. So I decided to open it and check for any signs of burn damage as I cam home the other day and the master fuse on the apartment was blown. I took out the network and USB card and put it back in. Success! The LED for traffic was on and it's working like a charm now. Thanks for your help!
ProSupport for Business
