TheDmac
Mar 30, 2016Aspirant
Network Drives Vanishing
I'm facing an odd issue here (which I assume is caused by a power saving feature or something), but if I don't access a network drive for a bit it'll simply vanish. One way the drives reappear is if ...
mdgm-ntgr
Mar 30, 2016NETGEAR Employee Retired
Which version of Windows are you running?
So you aren't using power saving features such as disk spin-down?
TheDmac
I am using Windows 7. I've included an image of my power settings below :)
- mdgm-ntgrMar 30, 2016NETGEAR Employee Retired
Which services and apps are you running on the ReadyNAS?
Which firmware are you running?- TheDmacMar 30, 2016Aspirant
Firmware 6.42 and the only thing installed is PLEX. I've since disabled it though as I discovered the 102 cannot transcode so I have the actual PLEX server running from a second PC now.
Thanks.
You answered which apps you are running, but you didn't answer the other half of the question about the services (e.g. SMB, AFP, anti-virus etc.)
