TheDmac
Mar 30, 2016Aspirant
Network Drives Vanishing
I'm facing an odd issue here (which I assume is caused by a power saving feature or something), but if I don't access a network drive for a bit it'll simply vanish. One way the drives reappear is if ...
TheDmac
I am using Windows 7. I've included an image of my power settings below :)
mdgm-ntgr
Mar 30, 2016NETGEAR Employee Retired
Which services and apps are you running on the ReadyNAS?
Which firmware are you running?
- TheDmacMar 30, 2016Aspirant
Firmware 6.42 and the only thing installed is PLEX. I've since disabled it though as I discovered the 102 cannot transcode so I have the actual PLEX server running from a second PC now.
- mdgm-ntgrMar 30, 2016NETGEAR Employee Retired
Thanks.
You answered which apps you are running, but you didn't answer the other half of the question about the services (e.g. SMB, AFP, anti-virus etc.)- TheDmacMar 30, 2016Aspirant
Sorry! Running SMB, FTP, HTTP, DLNA. No anti virus at this stage. Hopefully this answers your question :)
It hasn't done it again recently, but I am waiting to see if it does it again. The whole reason why this is such an issue is because the PLEX server will be grabbing the files via a mounted drive from the NAS.
