TheDmac
Mar 30, 2016Aspirant
Network Drives Vanishing
I'm facing an odd issue here (which I assume is caused by a power saving feature or something), but if I don't access a network drive for a bit it'll simply vanish. One way the drives reappear is if ...
TheDmac
Apr 07, 2016Aspirant
For future reference, the issue was Windows. I did what the answer said here and it's all sorted.
JennC
Apr 07, 2016NETGEAR Employee Retired
Hello TheDmac,
Thank you for sharing your resolution and/or workaround. We appreciate your contribution to the community.
Please mark the post that you think helped resolving the issue.
Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
