Kiwi20
Apr 10, 2016Follower
Network error code: 0x80070035
Hi I am unable to upload any files to the NAS since downloading windows 10. Every time I click on the NAS folder in the network it advises that windows can not access my NAS displaying error code...
jimmyv
Jun 26, 2016Aspirant
also im running a windows 10 and firmware 6.5.1
jimmyv
readynas cant find the nas and RAIDar has nog problem finding the nas.
- StephenBJun 26, 2016Guru - Experienced User
What model NAS and what firmware is it running?
- jimmyvJun 26, 2016Aspirant
problem solved, during testing the eth was changed from eth0 to eth1, after changing it back to eth0 with a ip address in the correct range, the problem was solved
- BenvandenBJul 03, 2016Aspirant
I have the same problem with my ReadyNAS 104. Since I upgraded the readynas firmware I get the same error code if I want to acces the readynas via Windows explorer. It states "No access to \\NAS-(number NAS). Check spelling of the name. Otherwise there is a problem with the network. Click on resolve network problems to solve problems on the network. Error code 0x80070035. Cannot find network path".
Clicking on resolve network problems does not provide solutions.
Can you provide details how you solved this with "net 1" and "net 0" ?
Thanks,
